Is there a FOSS PDF- viewer which is able to show double pages? If there is a photograph over two pages this would be very nice.
There are many PDF viewers on F-Droid. Did you try them ?
I tried some. It is cumbersome.
Unfortunately, in my opinion all FOSS pdf viewers suck. That’s why I use Xodo. I download new versions via the Linux application https://framagit.org/tuxicoman/googleplaydownloader. I’d love to use a good FOSS viewer though.
Unfortunately I have the same impression. Maybe it is difficult and time consuming to write a good reader.
Maybe your Linux application runs on Mac OS X too. A little (?) problem is my ignorance of Unix installation routine.
MuPDF does not suck. You can criticise their UI, but it works, and it do its job flawlessly with a simple and good UX.
No double page view, though.
Writing “a good anything” is always time consuming. But anyway, what FOSS lacks is good UI/UX designers.
You can use the multiplatform Raccoon. You just need Java runtime (JRE) installed on you Apple-machine and execute the.jar
file.
This topic was automatically closed 183 days after the last reply. New replies are no longer allowed.
