Good day to all!
I have a problem, but I do not know if it is better here or in the iodé forum… I’ll try it here for now:
I have a pair of Grell TWS/1 (Bluetooth in-ear headphones) to test here. There are two smartphones available for testing, but stupidly I still can’t test them because:
- pairing with a FP4 works fine, but there is the test build of CalyxOS on it. I can pair with it, but the Bluetooth codecs are broken. So it pairs, but I don’t hear anything.
- pairing with a FP3 with iodé does not work. At the beginning the headphones said: “Pairing failed” and on the FP3 always popped up a message that the PIN was wrong (in the lower part of the screen). Normally I would expect a dialog box asking if pairing is OK. But that does not appear. I then reset the headphones and also the Bluetooth settings on the FP3. This actually changed something: the error popup no longer appears. However, the headphones still say “Pairing failed”.
Is there anything else I can try?
By the way, I can pair other BT headphones, that’s not a problem, it just doesn’t work with the Grell.
