OTG and charging
I’m looking for a way of using OTG while charging my phone.
My main goal is to use a DisplayLink adapter I have lying around to connect the phone to a bigger screen.
So I bought this ICZI hub, which confirmed me that OTG works (I tested Ethernet, USB and SD, they all work – DisplayLink works as expected, audio over HDMI included, while of course the HDMI out in the hub does nothing). Problem is: the phone does not charge with this hub. :frowning:
Is there anyone who found a way to use OTG while charging with Fairphone 3? Is this actually even possible?
Thanks!
I doubt that OTG works. The FP3 has a USB-C port, but delivers only USB 2.0 through it.
Best wishes,
Thomas
OTG does work. The question was about charging while OTGing.
“USB OTG is a part of a supplement to the Universal Serial Bus (USB) 2.0 specification originally agreed upon in late 2001 and later revised.”
Hi serl,
I would have hoped this would work. Have you had a chance to, e.g., test another USB hub, or find another solution?
Sebastian.
very much indeed!
TL;DR: I did not find a suitable solution, I’m sending the hubs back.
So, I tested another USB hub, with the same anecdotal result (no charging). I decided to perform some more rigorous tests. Here’s the parts list:
  • Fairphone 3 :slight_smile:
  • ICZI hub
  • UGREEN hub
  • A DisplayLink USB3 to HDMI adapter I bought in 2015, now at the same URL there’s a new model
  • Lenovo X1 Carbon and its 45W charger
  • A standard phone 5V/1A charger
  • Old TV with HDMI and USB
The test is about the time to discharge the battery from 85% to 80%. The phone was always in airplane mode, screen on, maximum brightness. When the DisplayLink was connected, its app was active, the TV was on and plugged (I mean, I could see the phone’s image* on it).
Configuration 1st test 2nd test
Fairphone 3 alone 28’47" 29’52"
Fairphone 3 + ICZI hub 10’42" 10’41"
Fairphone 3 + UGREEN hub 13’53"
Fairphone 3 + ICZI + DisplayLink 4’18" 5’20"
Fairphone 3 + UGREEN + DisplayLink 6’26" 7’30"
Fairphone 3 + ICZI + DisplayLink + 45W charger 37’45" 28’47"
Fairphone 3 + UGREEN + DisplayLink + 45W charger 27’45" 30’54"
Fairphone 3 + ICZI + DisplayLink + phone charger 28’15" 30’55"
Fairphone 3 + UGREEN + DisplayLink + phone charger 24’30" 27’43"
Fairphone 3 + ICZI + DisplayLink + computer USB 25’37" 27’44"
Fairphone 3 + UGREEN + DisplayLink + computer USB 27’45" 25’38"
Fairphone 3 + ICZI + DisplayLink + TV USB 32’00" 28’50"
Fairphone 3 + UGREEN + DisplayLink + TV USB 30’56" 27’44"
You can see that anything plugged to the charging port of the hubs will help to avoid ultra-fast discharge. Also, in this case, size does not matter! Old TV USB port was enough.
Also, maybe important: even the PC does not charge with these hubs (PC<-hub<-45W charger)! No idea why.
My conclusion: I’m probably better off with some wireless screen sharing.
* In case you’re wondering: no, “Experimental desktop mode” does not work with DisplayLink, it is only mirroring.
Nice work, thanks for the patience it cost you. :slightly_smiling_face:
I have the same problem with some ethernet adapters like This or This.
What I find out is, it looks like that CONFIG_USB_MSM_ACA in drivers/usb/otg/msm_otg is not enabled, but for that you have to compile a new kernel.
I don’t know I’m on the right way, but this is all what I can find out.
Both adapters works fine on a Samsung Galaxy Tablet, so while charging, I have also Ethernet simultaneous. On the FP3, on one adapter Ethernet is working, with the other adapter it flapping every 5 seconds between charging and Ethernet.
