How can I start the camera without logging in first, as was possible in my Samsung galaxy 7?
Press the power button twice quickly and the camera will open.
Thanks Martin!!!
Does not work with my FP5 with Android 14, but with another FP4 with Android 13 it is working.
I can confirm that it does work on a fairphone 5.
By any chance, did you accidentally disabled this function in settings?
@wobbel Too confirm working on my FP5@A14
Are sure you have enabled Settings/System/Gestures/Quickly open camera ?
@ Rot FP5 with Android 13 or FP4?
Doens’t work on my FP5. Always get asked for PIN
Hmmm…
the first time you must unlock with PIN and in case of several Cam Apps installed confirm which one to use. Works perfectly fine on my FP5 as well. This feature exist since many Android Versions and I never had any issue on any FP with this.
FP5 Android 14. It works but sometimes it does not
Met vriendelijke groet,
Peter Rotte
Tummetott via Fairphone Community Forum forum@fairphone.com schreef op 17 augustus 2024 12:21:32 CEST:
Thank you for that switch, I don’t think I saw that before and turned it off. It works now, without asking for a pin.
