Open OS: Settings crash
Hi!
Running a rooted Fairphone Open OS with a long list of tools, never had a problem. I decided to install and use Lightning Launcher a few days ago. Don’t know what happened since then, but I can’t access the OS settings anymore, as every attempt result in a crash of the setting app. I’m pretty sure I didn’t uninstall anything related to the system. If I did that, didn’t notice it.
Is there a way to fix that? Thanks :slight_smile:
I’d try to clear the system cache via #dic:recoverymode.
EDIT - Well, glad the OS update was available. All seems fixed!
