Number of volume steps in FP6
Does anyone know if FP6 includes the possibility to increase the number of volume steps?
Standard Android only provides about 15 steps, meaning that volume jumps are too large.
Samsung provides a Samsung phone only utility (Sound Assistant) that allows the user to set the number of steps to any number between 1 and 150 which is really helpful.
TY!
Sounds like a software issue, and considering OS is open source it could always be improved, if needed. I should get mine tomorrow and then will let you know.
Hello jan4321, wondering how you are getting on with the fp6 and in particular if you had a chance to look into the number of volume steps? Ty in advance for any feedback.
Hello @KunjanChauhan,
It only has 15 steps
Best regards
