Number of ring tones before it goes to message
How can I increase the ring time on my Fairphone 4
Jim
Best way is to create your own ā€˜ring tone’ . I use an mp3 music file of over three minutes
does this extend the time before the call is fowarded to mailboxšŸ¤”
Have a look here and see if this works
I’ve never checked my mailbox :slight_smile:
Just checked my EE voice[mailbox] and I have none there
Since 2G, you can increase it to 30 sec max, unless your provider has a fixed setting (for example with Orange F it’s 20 sec.)
Maybe I’m wrong about the length of time my ring tone plays. I use a particular track for a few reasons, so maybe I’m so used to hearing it I think it never stops.
I’ll check to see if it is 20 or 30 seconds maybe :slight_smile:
It also maybe down to how long the caller can keep the connection alive ??
See this and following posts in the same thread.
I use a song as ring tone and it would never play till the end even if the caller would be that penetrant. @chantoine explained it its around 15-20-30seconds max.
Thats exactly as described in the article I linked to
Thank you all for your response. Dial a code 61*331100# then dial the 00 is the time your desire. You will get a return that confirms the new time. If it fails you will get ā€œinvalid MMI codeā€¦ā€ the It turns out that the length of time the phone rings is dependent on your service provider. I use Telekom. I was able to increase the length of time to 90 seconds. On my wife’s phone using Congstar I could not get more than 30 seconds.
Thank you all for replying Jim
Minor comment: your provider can set the maximum length. The code you dial allows you to choose a value less than or equal to the limit set by the provider.
I rather suspect (but haven’t made any tests), that if you try to set a value greater than the limit set by the provider, your request will be ignored (rather, for example, than resulting in a setting equal to the maximum value set by the provider).
Want your Samsung Galaxy Note to ring for longer? Here’s how to change the ring pattern.
Using the keypad, dial **61*Divert No.*11*N#
Then press the call key and you're all done.
N= number of seconds you’d like it to ring for (from 5 to 30 seconds). If you want to increase the number of times just enter a higher number for example for 25 seconds enter 25#.
Apparently in 5 sec increments
https://ee.co.uk/help/help-new/phones-and-devices/samsung/galaxy-note#top-tips/lengthen-ring-pattern
