Notifiction SD Card will thrown Out
Hi,…my FP 4 Shows notifiction:@ SD Karte wird ausgeworfen’ . Why is that. ?. What so I med to so?
Most likely your SD card is just a bit loose. The first thing to try would be to take out your SD card and put it back in just to make sure it’s in right.
Welcome to the community :wave:
You have accidentally used your e-mail address as the name that’s shown on your profile, so everyone can see your address at the moment.
You can change it under Preferences → Account and scroll a bit to the bottom to Name.
If any of @moderators has the power to hide this quickly, please do :pray:
Back to topic:
Was the SD card formatted as internal or external storage before? Are you still able to access the data on the card. Is the message reappearing after a reboot or does it only show up randomly?
