I don’t want any notifications to make a sound except text messages so I change the default notification sound to ‘None’. That works fine until I get a text, which also works as it should (i.e. makes a sound) but this seems to then change ALL notifications to the same sound. I have even downloaded a ‘Silent’ notification from a 3rd party app and set that as the default, but it doesn’t work. Also, when I go to reset the notification sound, nothing is selected. It is an annoying fault because any notification sounds like a text, such as calendar events, open wifi alerts, bluetooth connection etc. Is this a problem anyone else has seen?
Fairphone FP1, Cherry 1.6
