I have a brand new sim from T-Mobile and it’s connecting to data but I’m not able to access the internet
Can I ask if you have a $15 prepaid plan? The $10 is only like a gigabyte of data and it goes very quickly with heavy internet use even Wi-Fi calling uses cell data. A lot of websites use a lot of data. The only other thing is roaming and mobile data enabled in wi-fi settings? This is separate from mobile hotspot under carrier services.
I do not I’m on their prorated plan
How do you see that “it’s connecting to data”?
Did you double check the APN settings?
Did you try to disable advanced privacy (resp. especially the hidden IP there)?
I think I know why now, its because I still have my eSIM activated on my iPhone 14 Pro Max
I still have my iPhone 14 Pro Max active with my eSIM. So once I transfer my eSIM over to my Fairphone it should work.
Watch out when moving a SIM from an Apple phone to Android. I seem to remember there being a problem to do with SMS routing. Have a look at some of these.
