wackes
April 16, 2021, 11:10am
1
I had the same problem as many fellow users, that the official page for generating the “bootloader unlock code” does not work.
(Manage the bootloader of your FP3/FP3+ – Support )
On the community recommended site (FP3 'verify code' generator ) I get a code. However, when I use this code in OEM unlocking, a “no such phone” message appears and unlocking does not work!
Do you have any idea what the problem could be?
We had a discussion about the same problem in this thread:
Yes, let’s see if it’s a problem on the fairphone side. I would wait for their response before flashing either custom devinfo partitions or reconfigure my router. If I hear any solution from the support I will let you know, if you hear something @Keguira feel free to post here as well.
The community scripts don’t work for the new Android 10 version. I opened a support ticket but did not get any help there, yet.
@_tmp provided two other solutions in this post, but I didn’t want to try them before hearing from the official support:
For the adventurous there are in fact some other options:
flashing the devinfo partition using EDL mode, see Fairphone 3 unlocking without oem unlocking
trying to MITM the requests to the unlock server and faking a correct response as described here: /e/ OS Q (Android 10) for FP3/FP3+ - #14 by _tmp
(When I looked into the android 10 unlock code a few month ago it did not verify that the ssl certificate matches the hostname which is indicated by the not really correct WARNING: Hostname is not…
That’s all info I could gather so far. I am still trying to figure this one as well
system
Closed
October 16, 2021, 12:01am
3
