Hi so suddenly there is no sound in my left ear since yesterday and I’m not sure if it comes from the speaker or cable
I did try to unplug and replug the cable and it fixed the issue twice but it’s not working anymore
It’s kinda annoying I only have the headphones since Christmas and I don’t want to spend too much money and I especially don’t want to get a replacement piece and then discover I had to get another one
Any help is appreciated
Could you please tell us about which device you are talking? The Fairbuds XL probably?
Please be aware, this is just a user forum, no official support from the company.
Try different earphones on your phone, or try a different device with your earphones to see what element the problem is.
Hello @Fabulalice
If it happened after a drop or a shake it might be the middle cable coming loose.
You can reseat the cable and see if that works, it is just above the speakers
JC
