Recently I reinstalled FairphoneOS following the official guide following a long period on LineageOS. At first I thought everything worked flawlessly, but I later discovered that my phone now doesn’t connect to mobile data.
I’ve checked the sha256sum and made sure that I installed the correct file (assuming there is no regional difference). I’ve also tried enabling roaming, setting the mobile data carrier manually, and resetting all APN connection points with no success.
A thing worth mentioning is that I did not remove the SIM during the flashing, since I’ve never had to do that when flashing custom ROMs. I’ve been told that this shouldn’t be the cause, though I am planning on reflashing with the SIM card out when I get home to see if that helps.
If anyone knows any other possible causes or solutions that I could try out before my commute homewards, I’ll gladly listen!
