Everytime I want to use the NFC for paying or reading a yubikey I have to disable and enable it in the settings. Otherwise it is like turned off.
After a few minutes it crashes again and the above has to be repeated.
Which OS?
If you want to analyze yourself you might enable ADB debugging and have a look at the log.
If not it’s probably best to #contactsupport .
I don’t have to do similar things often. But to scan my YubiKey via NFC I often had to kill the YK app once before it works. Never had that with my Pixel. Now I just use the USB option to get OTP keys to save myself the frustration.
But sometimes I still need it on my phone, the problem is still present after more than a year. Never improved with updates and support doesn’t recognize the issue. Best you can do is #contactsupport. If enough people report it, they may fix it.
I do experience the same issue. When I was on FairphoneOS everything works fine but since I am on official LineageOS I have to restart NFC in the Quicksettings to react to inputs. Very annoying.
Edit:
After updating on February 5th it works fine.
