NFC for FP2 possible?
Hello together,
I read in several threads about the wish of users for a back cover with a NFC chipset. I am one of those.
Is anyone already working on something like that?
Do you know where one can buy a flat NFC module which is compatible to the expansion port on the backside of the FP2?
And was is needed on the software side?
I have no experience in doing projects like that. In this thread I want to estimate whether its a possible project for me or not.
Looks like a typical question for @dvl.
You might also find someting in this:
or this:
thread.
I am curious to know why you want NFC ? For now I think I have never actually seen a usage that justifies this module ^^
For example if you want to use Openkeychain with a Yubikey Neo (https://www.yubico.com/products/yubikey-hardware/yubikey-neo/)…
Hello
For device compatibility, please have a look there : ✏ FP2 : USB device compatibility
About NFC readers, for now only SCL3711 was tested, and sadly not reported working. Though it’s compatible with libnfc on Linux, so it might be possible for a developper to add support for it.
If you have any other NFC reader, please test it and contribute your results here.
For your key : "The YubiKey NEO has both contact (USB) and contactless (NFC, MIFARE)"
Did you try it straight over USB ?
Mifare is also definitely an option, as a contacless reader is reported working on the above wiki.
Thx for the answers
@BeMiGro
Hoped him to answer here. I know he would be the right one.
@nicop91
First of all I want to automate the lockscreen with nfc and llama…
And of course playing arount a lot :wink:
Yubikey also sounds nice.
@jaymanu
Thx for the overview. Didnt know it
Hello ,
After I received my new FP2 backplates with space for IC-breakouts I decided to give NFC a fair chance. My testing bases on the classic mifare RC522 breakout with I2C interface and FTDI’s FT201 usb converter. The challange and hard piece of work will be the software not the hardware. For the hw costs I guess the case backplate holds most of it. So I compared with typical offered usb readers around 50EUs . E.g. for ACR 122U NFC Reader an android app exists I admit it also works for FP2. My hw cost: 15EU . I wondered why FP’s decision on design studies went without it . Maybe the kernel inferface of FPOS even support more than I still know by now. However the space issue of modul integration maybe was too critical . Usually the cost I would say was not, but maybe they even tried to get below 500Eu.
Instead of kind of own driver in usb userspace FP-Open OS offer a chance to integrate OpenNFC into FP2’s android http://open-nfc.org/wp/editions/android/ . So, if you want to have now NFC turnkey ready an external usb reader would be your choice. Me as a developer I have no choice than for android integration. Because it hopefully enables most NFC apps. But I am not sure if it finds the official way into any kind of FP-OS(OS) that would be great honour to me , of course.
I would need NFC for reading my blood sugar value with the freestyle libre Sensor. There is an android app, which can do that.
