Yes, actually that’s what I did yesterday with my outlook account and today they are still there ! But it is annoying… I hope this will be solved with the next update.
Thanks a lot for your answer!
I’ve had two updates since the problem started. There’s been no acknowledgment from Fairphone so no. Hell, it’s been a week since opening another support ticket and I haven’t even gotten a response on that.
Dear Vincent,
I’m afraid this is a known issue that happened after the Android 6 update.
Our software team is currently working on this. Please make sure you keep your phone updated at all times
Our apologies for the inconvenience!
Adrian
☆ Fairphone || Buy a phone, join a movement!
✆ 09:30-17:30 CET under +31 20 788 4400
Having the same problem here - I can’t pick “local contacts” as an account to include in the contacts app - only Threem contacts available.
Though contacts does save new entries …
