Thanks, but it is no help for me. Always the same message “can not connect to camera”.
Walter
I have a similar problem with the new camera modules. They seemed to be working just fine, at first, but then I got one “cannot connect” message, and since then my camera app just hangs when I try to use it.
I’ll try reassembling. If that doesn’t work, I guess I’ll switch back to the old modules (I’m glad I haven’t sent them back for recycling yet) and try to get a refund.
UPDATED: I reassembled the phone, and cleaned the camera modules’ contacts with alcohol, and for now, the cameras are working.
In the instructions, it warns against tightening the screws too much. But, I think tightening them too little will also cause problems, because it means the electrical connections would be less secure. Just a thought.
After having my FP for 6 months. I also had problems with the connection of the camera. Sometimes my camera works, sometimes it doesn’t. So I read this whole topic very well. But now for the last week it worked well every day.
If the problems will come again. I hope to solve it by reassemble and clean the camera module. And I will take all your tips & trick about this in mind. So thanks everybody for this.
My phone has suddenly stopped communicating with the camera, even though I have not dropped or knocked it! I have tried rebooting several times, as well as trying to update the phone to no avail. I have disassembled both camera units, cleaned the contacts with alcohol, reassembled and still no connection with the camera!
I even tried restoring phone to factory data reset, but that did not help connect to the camera!
Sounds like a hardware defect. The fairphone troubleshooter will tell you what the optimal way is of filing a support request with Fairphone support.
Still the same with my camera. Today I sent a support request. I don’t know what to do anymore. I’m missing the camera so much. It’s so practicle to have always a camera in your bag without to lug always with a real camera.
Reading some of the other posts, about issues with focusing with the new camera module. I was wondering what sort of quality control/quality assurance agreements Fairphone as with the camera manufacturer? Is Fairphone being sold sub-standard units, as it is a small player?
Same issue and no answer from the support.
Seriously? How can it be possible that many people having the same problem?
What could be interesting in changing modules if it doesn’t work?
Honestly, I’m really thinking about change phone, because the bad quality of the camera is really a handicap…
And it is as much irritating as we don’t have any answer…
@Flora12 Support does not answer this forum, it is a community forum. If you want an answer from them, create a ticket.
Two people on the same forum is not immediately an indication of a big problem. For most users the camera just works fine. The modular design of the phone means there are slightly more problems - because the module contacts can be loose or accumulate dirt. But that is simply because no one ever built a modular phone before! Support may take some time to respond, but they are generally consumer-friendly: for instance some common defects are still sorted for free after the warranty term, which is quite special compared to ‘normal’ businesses who prefer to make money by selling a new phone.
Some parts have indeed been substandard - the cases and the screens - but those have been replaced by a newer edition which works well. The new camera is not one of them, it causes few problems. The software problems with the camera which people had in the beginning are mostly solved.
Thanks for your mail.
I know that it is a forum where support doesn’t answer. But I’ve made two tickets already, with no anwser…
My post were maybe too strong, I recognize it ; but you did answer to it, in opposit to my tickets…
A lot of people posted similar problem, I was so frustrated to not get any answer! And I purchased a new camera module for hollidays, but it did’nt worlk and my hollidays are past.
I know support team is really friendly and has a really good way to answer, I always put a good notation to the surveys.
But this time, I have been so disappointed to get no answer…
I really appreciated your approach business and your communication and I’m talking about Fairphone around me because I trust in your business ; I’m sorry to have been that agressive ; I might habe been more kind.
But I’m expected to get answer when it doesn’t work…
Thanks for your mail again. I’m though waiting for the team support answer (I don’t have other solution, too afraid to broke the new module by cleaning it, or by remove some joint peaces…). I hope ithe answer will arrive soon.
Thank you and sorry again,
Flora
Hello Flora,
It was not entirely clear from your post that you had already contacted Support about this issue. Some helpful forum users have written a guide, out of their experience, about how to deal with the Fairphone Support, which you can find at: The Forum Guide to... Fairphone Support (scroll down to ‘Contacting Support’).
I would suggest taking a look there, how to speed up the process. Especially calling Fairphone often helps - keep your ticket number(s) at hand when doing so.
Hope this helps.
Albert
I did do as Mette Soegaard mention in a post December 17, but still no joy. I cannot reload some of my apps, I had before I resorted to factory settings. Even though I am using OS 18.04.1, Google is not allowing me to connect to even its Playstore. So basically, I have a very expensive dumb mobile phone.
Hi everyone,
What I did worked finally. I updated the last version of Fairphone software.
Thanks for Fairphone support ; the answer was late but helpfull though.
Hope it work for you!
Flora
After replacing the old camera module (PF-CAM01) with the new one (PF-CAM02), the new camera was not recognized at all. After reading posts here, I
- cleaned the contacts with alcohol and a cotton swab
- removed the tiny black rings/washers as suggested by Mette_Soegaard’s post
- screwed in the 3 screws more tightly than before (of course, don’t apply force like mad)
It did the trick for me, it seems, the new camera is recognized !
(BTW, I did not receive any notifications about new hardware and did not have to change settings of the Camera app.)
You have had better luck than me, camera still not connecting, even with recent update!
Thank you, this solved it for me!! Scary taking apart the phone for the first time, but all the comments here and video https://www.youtube.com/watch?v=ggIPpbze8ec really helped.
