New battery for 3+
Is a fairphone 3 battery compatible with a fairphone 3+?
Welcome to the Community Forum. :slight_smile:
Yes, the FP3 and the FP3+ use the same battery:
(Note the line right above the price line)
Hi and welcome to the forum.
How long have you had the phone as it has a two year warranty which includes the battery?
Has the battery become swollen and unsafe to use or do you think it’s not lasting long enough?
You can do a battery test vi the phone dialer
Dial# *#*#66*#*# Then service tests > Test Single > Battery status check.
To prologue use you can limit the charging routine:
  • Never charge overnight to 100% as it will stay like that until you unplug
  • Some say charge between 20 and 80 percent, I prefer 30% and 90%
The main damage is done by heat, so if it is warm charge a little more frequently
The FP3 and the FP3+ are the same phone, the only difference is that the + has a better camera. The naming is just marketing, the FP2 also got a camera upgrade back in the day and they didn’t name that one FP2+ either.
Not quite :slight_smile: The FP3+ has a different core module with an enhanced audio chip and registers as a different module under . . . Settings > About Phone > Model > Hardware version
Common misconception, details here (note the link to an even more detailed PDF) …
