Hi together,
i love my fairphone 1 and dont want to get it up!
My Usb adapter is not working, so charching isn´t possible…
is there anybody who is able to help getting a new one? any ideas?
Greetings, Maren
Yep, #repairshops can resolder the USB connector. If they need a new part, this one fits well.
Good luck! If you find a new repair shop that is not on the list yet, please add it.
Thanks. i´ll have a try
For a temporary fix, you can buy a universal charger that fits the 5.3 cm FP1 battery and allows to charge the battery outside the FP1. Easy to find online.
