I got an old LG Travel Adapter Model STA-U12ED with MicroUSB, 5.1V 0.7A
The FP2 accessoire charger specs for EU say 5.0V 1.0A
I’m only curious if this could create any issues.
That charger should be fine. 0.7 A means that the battery might be charged slower than with a charger that provides a current of 1 A.
So I think also you are safe with this charger, because it is a USB charger it has to be certified by the USB specifications with which also the FP2 has to be compatible…
Cheers, Robert
Thanks for the research, good to know
Thank you very much for the information.
