I have loaded music files to listen to. FP2. No prob. But, how do I get to use my music files as alarm & notification sounds?
Copy the files to your internal storage /Storage/emulated/0 to the folder Ringtones and to Alarms. You can use the app Amaze.
These need to be in the folder /storage/emulated/0/Alarms or /storage/emulated/0/Notifications. Then you can access them for the alarm.
