Hi Guys,
Question,
My FP4 is got a reverse ip lookup with client.nordic.tel domain on it and port 5060 is open.
Anyone know what this is? and why?
client.nordic.tel:5060/tcp filtered sip
Thanks
Hi Guys,
Question,
Thanks
Seems to be a carrier, are you located there by any chance?
Port 5060 is, according to Wikipedia, used for VoLTE among other things.
No, in NL.
That is what makes this strange.
That is indeed very strange
Could this be some kind of provisioning by your carrier to enable VoLTE while roaming?
If you disable mobile connectivity and only use Wi-Fi, does it still show up?
Thanks,
I tried your suggestion no change.
I found the issue.
It is my network config and the open network of nordic.tel.
I fixed this issue, just bad luck, by chance I config my network IP range to the same one as nordic.tel, seen that this is a telocom provider, my phone got a nordic.tel. hostname when it connected.
So, I changed my ip rage
Anyway,
Thanks for you help.
