My FP3 Fingerprint sensor is working so badly it's basically completely useless
Support goes with the easiest solution which most likely solves the issue. It actually makes sense. Same with cleaning the fingerprint reader.
Almost every time I had issues with the reader, the above solved the issue.
I recommend to register more than one finger in case one gets a cut or gets worn off due to labor/sports/washing. (These are the other three reasons I had issues.)
That it sometimes fails is true, but then it succeeds if you reput the finger at a different angle. You could use that to get it disabled under duress such as a thief forcing you to unlock.
Really! I’ be more worried about violence from the thief than them having access to my phone. :rofl:
I mean you’re not talking about a really nice thief, are you, who asks you for money, and when you say no, they apologise and walk away, without a backwards swipe.
Yes, really. You can delay time this way, which increases the time the thief is vulnerable. Some thieves are violent, some not.
In theory a thief could threaten you to open your bank account on your smartphone, and send them money. Yet we never hear about this stuff.
I’ve seen that on many movies, but not had such an approach. :slight_smile:
AH and I don’t have banking apps : be sure to let all those nice non-violent thieves know :slight_smile:
What would be nice is a secondary boot partition that you can open with a finger print that automatically does this and that ~ enable location ~ call the police ~take pictures of the thief with real-time upload ~ block accounts etc.
You keep ridiculing this ‘non-violent’ thief thing. Violent isn’t a binary thing. I’ve been mugged and I’ve been threatened, there’s a variety of degrees such can happen. One time end of 90s the mugger was so disappointed, they allowed me to keep my 10 guilders (~5 EUR). After being asked if I really didn’t have more, and I kept saying no, they let me go.
pam-duress allows this on Linux, except for the secondary boot partition (the device is normally already booted up). What it would allow is say automatically notifying IT of a breach, call the police, remove all data, or revoke authorizations, or reboot. I’m not sure if Android uses or allows PAM though.
Sure polarisation is an issue, but that’s what happens, people find problems and then want solutions, some think they have a solution to some else’s problem and then go looking to sell the solution.
Sadly most things seem to either one or the other, the future or the past, walk left or walk right. What I’m saying is there is no solution that fits the thief and violence may be used to find a solution.
It is ridiculous, that doesn’t mean it isn’t true.
So how ridiculous is a fingerprint reader if it doesn’t do what you want. I am the thief and that to be stolen but I am not the victim.
That’s why a duress authentication would be useful.
Totally agree. Mine doesn’t work either and now I’m locked out of loads of finance apps.
I really do NOT enjoy this phone.
Hi and welcome to the forum.
What have you tried to mitigate.
  • Cleared the old and tried alternative fingers
  • Tried covering the sensor with transparent tape, as has been sucessful for some.
Have a look at this post. When registering it’s important to leave your finger on the sensor at each touch until instructed to lift it.
I also had many problems with the fingerprint reader. Many times it did not find my finger and lock me out of using the reader.
What I did, and it seems to solved it for me is the following.
When registering a new fingerprint, first put your finger dead center on the scanner. Then try to put your finger on the scanner as far away from the center as possible from each direction (up, down, etc.). It will complain sometimes that a partial fingerprint is found. Keep trying to move your finger slightly until it is accepted. After this, my unlock success rate is much higher. I can almost trust it that it will not lock me out. Still, a misread is still happening sometimes.
All good points but I want to explicitly second this one. That’s also what I do: Clean glasses, FP3 screen, and then fingerprint sensor (in that order, being careful to spray the cleaning stuff only on my glasses).
Apparently the fingerprint sensor has issues with moisture. More than the fingerprint sensor on other phones that I have used before. So if you constantly have issues with this it might actually be worth to check if you might suffer from hyperhidrosis.
I wouldn’t point fingers at the users. Hyperhidrosis seems to be an issue for only 1-2% of people and I doubt they are all here in this thread :wink:
It works really badly for me as well once I have the slightest bit of sweat on my fingertips. That means on warm days, with slightly higher temperature at the office, cold sweet etc. I am constantly cleaning the sensor, rubbing my hands dry or just giving up and entering the passcode - eyeing the iPhones and Pixels of my colleges enviously which open without fail (not to mention the cameras).
And regarding other sensors and hyperhidrosis, I just found this on Reddit:
After browsing a bit, a fellow Redditor jokingly said to make a fingerprint scan of your sweaty fingers. Not a bad idea. I gave it a shot and made fingerprint scans of two of my fingers (while sweating).
… Low and behold! It worked!
https://www.reddit.com/r/Hyperhidrosis/comments/tobwys/fingerprint_scan_phone_with_sweaty_hands_solution/
Yes scanning fingerprints in different conditions is a must for frequent viability. I work in the field a lot, dirty, wet, very dry etc.
I never expected one fingerprint to cover all as they clearly change depending upon condition. :slight_smile:
Indeed, but luckily nobody seems to have done that in this thread yet. :wink:
Personally I don’t have any issues whatsoever anymore with the fingerprint reader of my FP3 . I wrote the post that you partially quoted as it might contain infos that are relevant for others and at the same time deliberately phrased it as cautiously as I did as it most likely isn’t relevant for most people here.
I have a refurbished FP3 and exactly the same experience. It’s really problematic
May I refer you to post 52 above in this topic, and the link it contains.
Yes welcome.
if you search you will also find some users have stuck a bit of sellotape over the sensor and had effective results.
adhesive tape really works
