Mobile internet connection doesn`t work with FP Open OS!
since i have updatet my fairphone2 to fairphone open os(16.10.0) it doesn`t recieve mobile data! Does anybody know how i can solve this problem?!
Check out your APN settings. Search for the ones for your network operator if they are not automatically detected.
Also check if your roaming data config is checked or not. In France for example Free Mobile uses Orange’s network and it counts as roaming so if you don’t activate it you won’t have data.
Thank you! Problem is solved now! :+1:
Could you write how you solved your problem please so that someone with the same might find some help by googling this thread ?
Oh yes! I have searched for the APN of my cellphone provider. After i`ve found it, i entered it manually in the APN settings of my phone.
