https://forum.fairphone.com/t/missing-entries-in-calendar/?source_topic_id=37984
The problem happens when I create a new entry in the Calendar and I am not on a Wi-Fi network. This is especially true when I create a new Calendar entry and there is no coverage. The result is that this new entry sometimes disappears after a while. (When I have the Internet and synchronize my Calendar with my email account, the Calendar entry I just created will never disappear).
This might not be the solution you’d prefer but probably with a local calendar you will not have those problems (i.e. calendars not being synchronized with any cloud). I can recommend Offline Calendar for creating local calendars.
Although I don’t know for sure I guess you can then synchronize your local calendars with a cloud - but I can’t tell you if and how, I don’t use those services.
