Hi, i have fp3+, and looking in the settings for the camera grid, and can’t find it. How can i add grid?
Hi could you detail
- What OS and version
- Which camera are you using
Yes I’m having a problem finding in the default camera Version 3
I do have it on a GCam app [Nikita} if you are happy to install manually
EDIT:
I couldn’t find them in Open Camera but the post below made me search better.
Easier to install from F-Droid than the Gcam
OpenCamera has a large selection of grids.
Try the following steps:
Open the Camera app on your Fairphone 3+.
Tap on the three dots in the upper right corner to access the camera settings.
Scroll down and tap on “Grid lines.”
Select the grid type that you prefer (e.g. 3x3, 4x4, etc.).
Hi and welcome to the forum
What camera app are you using, the OP has yes provided that info ? There are no three dots on the default camera
