I find it really annoying / pointless that the Minutes spinner in Calendar Event Time gives 1-minute resolution. The default is 00, and I often need to select 30 as lots of things start at half-past. Why do I have to scroll tediously through every single minute? Can’t I have 5 or 10 minute increments?
Worse, if I select a start time of xx:30, the end time then defaults to xx:30, but I often need to wind that back to 00, so here I go again!
If you tap the minutes number, the keyboard appears and you can set it directly.
Thanks for that. I hadn’t discovered that. Yet another thing which is probably obvious to old hands but not to newcomers.
Trying it out, it’s very temperamental, it has to be tapped Just So to get the keyboard to appear.
This topic was automatically closed after 5 days. New replies are no longer allowed.
