When calling, the volume of the actual call is way too loud, even set to the lowest possible volume. It’s def not set to be loud on speaker, that’s what I first thought. How to dial the call volume down some more so it’s not hurting my ears?
Hey, maybe you could download an app that’d allow you to lower the volume even more?
And make sure to contact [EDIT : your OS’] support to make them aware of the issue, so it’d be fixed in a future update!
As e/OS is used, FP support will not help and murena support should be contacted.
My mistake, I hadn’t checked the tags
