Hello ,
I’m now stuck. My sdcard is not visible and the process of installing it in the storage menu doesnt work.
I have a 64gb sandisk microsd
Or this one?
Thanks , yes I searched but you found some good topics i will find a way
But erasing it didn’t work.
Oh, you have the same problem with a Sandisk…I was hoping it was just an issue with Samsung cards as two users reported this. Mine doesn’t recognise the card in 3 out of 4 reboots now and I was thinking about just buying a sandisk.
I have another sandisk offre 34gb i Will try and tell you the result.
I have the same problem, sd card not detected, it’s a Lexar 16GB.
OK now it works well with a 32Gb Sandisk ultra HC . the other one was a sc one maybe it could be the problem . and I use the program sandisk memory zone and it works Well til now !
Thanks for your help!!
Greetings to all of you
Good to know! @icelandeek is your card also SC and can other people with the same problem maybe check on this?
