Microphone turns off for hangout’s app when earphones are jacked in.
Internet suggested “select TYY VCO” but can’t find any.
What else should I try?
Thank you,
Thank you,
Your phone probably thinks your headphones have a built-in microphone, and it’s switching over to that. But it isn’t there, so you get no microphone functionality at all.
There’s an XPosed module called ‘Force Phone Microphone’ that fixes the issue - just tested it, and it works for normal phone calls and my audio recorder app. You need root access and XPosed framework for that, though.
