[I noticed that my microphone stops working for audio and video recordings after I have used my FP3 in my car. Problem can be solved by restarting the phone, but it is very annoying. Is there any way to fix this problem in the settings?
Could you please add the system and version your FP3 is running and how you connect to car, BT, cable…
I’m using FP3 with Android Version 11. I connect to car both by USB-C cable. Connecting through BT is possible, but is very unstable.
