I would like to know where the microphone(s) is/are located for records with the soundrecorder, that means how should I place the FP to get a stereo sound. Or doesn’t it matter, and stereo sound is not possible?
I think it’s the small hole at the camera. But no stereo, i am afraid.
I am not sure which recorder software uses which mic, just try.
Nope. Records at the phone mic. Hole at the bottom of the phone. You can see it when you tap on the mic hole during recording: the volume peaks, instantly.
I don’t think that hole near the camera actually is a mic.
Maybe the hole is there to get the dust behind the transparent cover of the lens…
