Microphone doesn't record sound as
Hey there,
I have an issue with my microphone from time to time. I have an FP3 and have updated the latest software.
When I use Whatsapp calls or Signal calls, no sound is recorded. The same with the microphone when I want to dictate some text in a notes app.
When I restart the phone, the issue is resolved for a while. But after a few hours it doesn’t work again.
What could be the reason?
I have tried
Settings > Privacy > Permission manger > Microphone
The settings are okay (allow when using the app).
I did
dialling ##66## > Service tests > Test single > Microphone
And the tests are okay, when the micro is working. But none of the microphones is recording sound when it is not working.
I try to avoid a factory reset.
I am looking forward to your answers.
P.S.
There was a similar case here:
From which I took the ideas of what I can try.
I am sure the microphones are not covered. I use my phone as regularly.
Sounds like some app is messing things up once it’s got going.
Could you try using Safe Mode? This sort of temporarily simulates a factory reset but without the pain.
If Safe Mode allows stable microphone functioning then I would advocate making an exhaustive list of apps that are allowed access to the mics, and remove their permissions - one by one so that you can find the culprit. I suppose you could also work the other way: withdraw permission for all apps and then gradually grant again.
To list all apps with mic permission,
  • go to Settings > Apps > See all apps
  • choose an app that you know has mic permission
  • tap “Permissions”
  • tap “Microphone” > See all apps with this permission.
Thank you! Currently it’s working fine without doing anything. I will try out as soon as the microphone issue reoccurs and Keep you up to date.
I have the same problem every few weeks (not hours) but I don’t use the mic much and only notice it wasn’t recording when I e.g. play a video some days later and find out has no sound. BirdNET sometimes doesn’t hear anything but I notice that immediately from the empty audio track. Only solution I know is to restart the phone.
