Micro SD card not recognized by FP2
Hi guys
Just got the FP2 and it still shows a no sim card icon on the top right even though I have a sim in there and can make calls with a full signal bar. I looked at the sim slots and it shows slot 1 occupied and sim slot 2 empty as it should be.
Also, it doesn’t seem to be showing my SD card!
Any help welcome
Thanks
There should be 2 symbols, according to the 2 SIM slots of the FP2.
If you put 1 SIM in your phone and have 1 “no SIM”-Symbol, then everything is as it should be.
Thank you very much for the quick reply.
My only problem now is that the micro SD card doesn’t show up.
Thanks
Oh I over-read that.
When you open Amaze and tap the burger-menu-button (top left corner) is your SD card not listed there?
Did you try taking it out and putting it back in again?
No, I have a micro SD card and it’s not showing up in Amaze. Tried taking it out and back in again.
Ok than that seems to be a bigger problem.
I updated the topic title accordingly so people who can help you will find the topic.
Does the micro SD card still work in other devices?
Someone else wrote that he destroyed his micro SD by putting it into the FP2.
Thank you very much Paul. I remounted the SD card and unmounted it and that did the trick.
So, all sorted now.
Thanks again for the help :smile:
Bas
