Typing in Fennec has always been a bit quirky (I used the volume buttons to move the cursor left/right, which is a Gravitybox setting and after one Fennec update it stopped working (wouldn’t go beyond the last letter of a word and jump to it when you come from left).
After the latest Fennec update it has become virtually unusable. I deactivated the respective setting in Gravitybox, and still there are problems:
- when I manually click somewhere to move the cursor and type something it often is still appended at the bottom of the text field.
- when I try to delete a word, it gets pasted into the text field multiple times after each other. (Similar to this Fennec bug report. Here is a screenshot:
Can you confirm this behaviour?
Edit: If I disable the dictionary/correction suggestions, the problem disappears. This is only a workaround though because I’d still like to have the suggestions displayed above the keyboard.
Ps: I’m on Android Kitkat 4.4.2 and have recently made backups with Titanium Backup and CWM and also have installed a different ROM build and switched back to Macadamia.
