Thanks for your tip. I dont remember if I tried that. Did you really get it to work on your FP ?
I had problems with Magisk uninstalling itself, the manager app suddenly telling me Magisk was not installed.
I also tried to relock the bootloader but the FP would not boot (hopefully It did not brick, like with other phones!)
I was struggling on that for hours, to have something working temporarily, I abandoned.
That was enough for me :).
Yes, it works for me. Iβm not using LineageOS though, Iβm still on stock. And I did not uninstall the manager. Instead I use a root app (OAndBackupX) do disable the Magisk Manager. I can re-enable it whenever I need it (e.g. before installing firmware updates).
Nun immer wieder was neues, damit meine Banking-App mich wieder mochte nach Magisk 24.1 - musste ich Zygisk(Beta) einschalten, dann Verweigurungsliste erzwingen und Verweigerungsliste die Bankingapp und Google-Pay auswΓ€hlen. Dann mochte beides wieder.
