Fairphone 2
OS: Fairphone Open 18.0.1.1
pre-installed phone app
The maximal volume of the loud speaker for phone calls using the pre-installed app is very low and does not suffice.
When I make phone calls using Linphone the volume is fine. Also listening music using the loud speaker works well.
Any idea why the loud speaker is so quiet for phone calls ?
A bug report for this issue has been open since October 2017. You might want to chime in there to make sure the devs learn about the size of this problem.
I’m afraid to say I have also got this problem. I often have to make calls in noisy environments - but this is not possible which is why I’m now looking at returning my FP2; which makes me very sad!
Same here, it’s kinda annoying… When using it, because more people need to talk or the phone is lying down, the highest volume isn’t load enough to hear what the other end is saying… Music or other apps can be really load, so it must be the software, not the speaker.
Same here, but bizarrely when I used a second SIM card for work calls the speaker volume worked fine. Sadly, just swapping the primary SIM into the second slot had no effect.
Same problem. Works in other apps, but calls are quiet on loudspeaker. This problem has been here for ages. I just bought a second FP2 after few years and it has all the problems the first one has. Twitchy display and dim too, non-functional long press, restart loops, bad bluetooth quality, camera from the 20th century and sim slot 1 doesn’t work. It also refuses to charge in most chargers without freezing the display and doesn’t have USB-C.
People ask me about the phone and I have to tell them that the Fairphone philosophy of ethics is great, but if they want to make phonecalls they should stay away for now.
