Lost network and SIM card connection in cold weather / low temperatures
As other users have reported in previous years, my sim card loses contact (and hence the phone connectivity) when it gets “too cold” (external temperatures ~ < +5°C).
Has anyone been able to solve this problem? Despite a lot of tips, there are no reports of this problem being successfully solved.
Tips include:
  • changing the SIM card
  • changing SIM slots
  • using contact oil
  • bending the contact pins
Changing the sim cards or their slots doesn’t show any improvements.
The pins are inaccessible in FP3, and I shy away from using any oil in these sensitive mechanics.
Many thanks,
Steffen
If you tried both sim-slots, I would argue it is extremly unlikely they both have the exact same issue. Especially if one slot was occupied most of the time while the other wasn’t.
I think your simcard or something else with the phone is the culprit. Whenever I had the issue (which was very rarely) I restarted the phone and the sim was back online.
I had the issue with a different (old and new) sim card as well. Restarting doesn’t help.
I think the culprit may be some internal connection that gets “loose” when cold. But then I would need a new phone…
PS: The issue is not rare but very replicable. When I leave the house now (around 3-5°Ç outside), the sim will switch off after 2-3 minutes in the cold, and switch on again when I keep the phone in my pocket for a few minutes.
