Hallo zusammen!
Ich bin dabei Lineage OS auf dem Fairphone 3+ zu installieren. Ich habe mich an die Installationsanweisung von Lineage gehalten (Install LineageOS on FP3 | LineageOS Wiki).
Nur leider funktioniert die Kommunikation zwischen PC und Handy nicht. Obwohl ich eigentlich alle Schritte befolgt habe: den universal adb driver am pc installieren, usb debbuging aktivieren, oem unlock am Handy.
Was nicht funktioniert hat:
“Setting up adb:
6. On the computer, open up a terminal/command prompt and type adb devices.
7. A dialog should show on your device, asking you to allow usb debugging. Check “always allow”, and choose “OK”.”
→ Wenn ich in der Eingabeaufforderung am PC “adb devices” eingebe, öffnet sich kein Dialogfeld am Handy.
Und wenn ich mein Handy in den fastboot mode bringe, steht im fastboot mode u.a. “device status - locked”.
Kann mir bitte wer weiterhelfen?
LG Clara
Hello everyone!
I am in the process of installing Lineage OS on the Fairphone 3+. I followed the installation instructions from Lineage (Install LineageOS on FP3 | LineageOS Wiki).
Unfortunately, the communication between the PC and the phone does not work. Although I actually followed all steps: install the universal adb driver on the pc, enable usb debbugging, oem unlock on the phone.
What didn’t work:
“Setting up adb:
6. on the computer, open up a terminal/command prompt and type adb devices.
7. a dialogue should show on your device, asking you to allow usb debugging. Check “always allow”, and choose “OK”.”
→ When I type “adb devices” in the prompt on the PC, no dialogue box opens on the phone.
And when I put my phone into fastboot mode, one of the messages in fastboot mode is “device status - locked”.
Can someone please help me?
LG Clara
