Looking for a NFC app for credit card paiment with fairphone 6 murena
I am looking for an app for NFC paiement by my phone, but i cannot find one which would be working (indeed, google wallet for example, doesn’t work) and an app which would for free if it is possible ?
Do you know a great one comaptible with e/os murena ?
Thank you very much !!
“Curve” is the “temporary” workaround that was recommended by /e/ managers.
Hi! NFC payments on /e/OS (Murena) can be a bit tricky since not all apps are supported yet. Google Wallet often doesn’t work because /e/OS doesn’t include Google Play Services by default.
A few options you could try:
PayPal – They have an NFC payment option in some countries, and you can use it without Google Wallet.
Open Source Wallets – Apps like DroidWallet or OpenWallet sometimes work with /e/OS, though support can vary depending on your bank.
Bank-Specific Apps – Some banks offer their own NFC payment apps that are compatible with Android without relying on Google services. It’s worth checking if your bank has one.
If you want a free option, look for apps that don’t require a subscription and can link directly to your debit or credit card. Keep in mind that not every NFC terminal will support these third-party wallets, so testing at your local stores is a good idea.
Today I tried the Bizum Pay app to make an NFC payment, and it worked perfectly. My bank’s app—Abanca—integrates Bizum payments, making the whole process easy.
It also scores 7 out of 10 for privacy, far better than other recommended apps that score 0 out of 10.
Greetings from Spain.
