Hi! I dropped my phone and now my display is very fuzzy, bascally I can barely send texts and answer phone calls (not ideal). Before buying a brand new module, i would like to check here if anyone sells a display module suitable for FP3?
Thanks a lot!
Welcome to the community
Have you already dismounted and remounted the display? Or does it look physically damaged on the outside?
Hi! Thanks for your answer, yes I did it and basically the top part of the display module itself has phisically diconnected from the bottom part, this made me realise that the module itself is probably broken
Plus dismounting the module made the damage worse. Do you know if I can get it repaired somehow?
ok, quite obviously physically broken. Certainly needs to be replaced.
