Since I got fast help for my other problem which is now solved, I need the communities help again.
I cannot find an option in my FP3 to disable the swipe (“control center”) function in the lock screen. In my opinion Wi-Fi or mobile connection should not be able to disable while the phone is locked for safety reasons. So how is it possible? (iOS noob here ^^)
Until somebody finds a setting for this (my internet search suggests Google didn’t implement this yet in standard Android, which Fairphone OS is very close to, in contrast to e.g. Samsung’s Android, which apparently has this feature added by Samsung) … options:
remove from the quick settings menu every tile you don’t want anybody to have available on the lock screen (when you pull the quick settings all the way down, you can tap on the pencil icon to edit the menu) … then of course you can’t use the removed tiles at all yourself.
