I use FP Open OS with F-Droid and Aurora Store to install applications. Map applications (for example Google Maps) are not able to detect my location (I have it enabled in Settings). I don’t know where the problem can come from or how to fix it. I appreciate the help you can give me.
To start you could try the #gpsguide and then tell us if any tips there made a difference.
I installed (and configure) F-Droid app’s “UnifiedNlp (No GAPPS)”, “MozillaNlpBackend” and “Déjà Vu - A local RF based back end for the µg Pro” and evething all right!!!
Several days have passed and the GPS has stopped working again. What has happened? How can I fix it definitively? Thank you.
