loading a FP2 with a rarely used power supply: after some minutes it feels like a loose connection (“Wackelkontakt”), the display is activated and the LED (as a signal of the loading process) is blinking in irregulary intervals.
I assume it is yellow then and not red blinking due to being below 15% charge level?
So maybe until now you have tested another charger+cable and also tried to hook up the phone to a computers USB port?
Is the phone getting warm on the back side? (the charging process is internally interrupted if the temperature exceeds ~42°C)
Have you also tested any way of charging while the phone is powered down?
