LineageOS 15.1 no 4G
Hi, I’ve LineageOS 15.1 on FP2, 2 sim. First SIM to navigate,send sms and call, Second SIM only for answer call.
Sim1 works only in Edge (E) no 3G or 4G. My provider have 4G network
suggestions?
Did you checked under Settings -> network and internet -> mobile network -> then down “advanced” or “expand” -> prefered network type?
You can set it for every SIM card
I’ve set LTE alwayse
On both SIM-cards? You can set it individually
LTE above, I’ve set Mobile data ony on first SIM
Speedtest:
Dwn:0.07 Mbps
Up: 0.05 Mbps
Can you try
  1. removing one Sim card and see if LTE works then?
  2. with two Sim cards set second Sim to 2G
Chris
1 With only 1 Sim 5,29 Mbps than 3G works
2 I’ve set second Sim to 2G and LTE works fine
Thank you @chrmhoffmann
