Lineage OS 17.1 system files size - 13GB
I’ve recently upgraded to Lineage OS 17.1 from 16. Looking at the storage manager its saying that system files are 13GB whch seems a bit big.
Is that right or has something gone wrong?
Thanks in advance.
Mine says 14G, so…
This seems to be normal, I have 14 GB with /e/OS (Android 10).
Thanks both. I suppose I was puzzled because LOS 17.1 is only 4.8GB on my FP2, so was wondering if I maybe had an old OS or two I had tried in the past taking up the space.
I had a similar problem with another phone, and I wiped one of the partitions with TWRP (this helped), but I’m not sure if thats posible with LOS 17.1 as it doesnt seem to use TWRP anymore.
