Yeah, I went from bad performance on LOS16 to bad performance on LOS17.1 so… yeah, really, it did not get worse for me
Maybe when I get around to it I will do a completely clean install. What’s the best way for this? Restore to factory settings in LOS oder deletion of … stuff … in CWM?
Another question: Is there any way to modify the standard vibration for incoming messages? I remember, back in the olden days of Cyanogenmod, you could directly set length and possible intervals. I miss that.
Here LOS 17.1 and OpenGapps pico. I have the problem with turning mobile data off and on. And it takes some time until the phone let’s me unlock it with my pin after a (re)boot. Everything else works fine.
I have not had any issues to reconnect to mobile data when turning back on, neither with SIM 1 nor with SIM2…my FP2 is not rootet, could that be a reason? However I also need to patient after a reboot before I can enter SIM Pins and phone PIN…
I can confirm. since 17.1 the FP2 is very slow and reacts very very sluggishly. Android 10 is too fat a number for the old phone?
Otherwise the port works perfectly.
Under LOS17.1 20200426 my FP2 takes much longer to get a GPS fix than under 16.0, although it recognizes a number of satellites in a short time, that was more than enough to get a fix under 16.0. Can anyone confirm?
To me it also seems, that it take a longer time to get the GPS position (tried only with GPS enabled without mobile network and WiFi).
But until now I only tried it 5 times or so.
