Lineage-16.0 (Android Pie) Nightly
#lineageos is at Android 9.0 currently on the Fairphone 2, with Android 10.0 (as LineageOS 17.0) coming up.
Here’s more … https://wiki.lineageos.org/devices/FP2
I’m already at android 10, but it’s still very experimental and some apps including Gmail don’t work as well as enything that has sth to do with filemanagement. I’m still running an older version, maybe an update will fix it
Just for those using microG or UnifiedNlp alone: there’s a new release available for the microG/UnifiedNlp installer from the WeAreFairphone community:
This update includes support for Lineage OS 16 (Android 9 Pie) at last! We are also working on the Lineage OS 17 (Android 10) support (here, if you are curious).
This thread can be closed now. Lineage-16.0 support is over with the release of 17.1.
If you do not want to upgrade right now, you should at least upgrade to the last version of 16.0 before it disappears.
Chris
It may be a good idea to download the latest 16.0 image now (or keep the one you have installed and know is working). Just in case. :wink:
