Will the upcoming version of FP OS still support the launcher v2? I got used to it.
(Mods, you might want to move this into an existing topic, but the ones I found appropriate for this are already closed, thanks)
It will support it, but v3 will be pre-installed. But:
You should be able to extract the old launcher from the existing *.zip-files. Then simply install it on the new OS and restore your backup from the old OS.
