is the 2420 mAh Battery which lasts me about 1, maybe 2 days (depending on usage)
Woah. My barely lasts 6 hours if I’m lucky. I’ve never had it go a day without needing a charge! (and that’s two phones after my first was replaced because it kept crashing!)
@delanthear, I’m also inclined to think it’s caused by one of your apps, as my phone with a 2,5 year old 2420 mAh battery usually lasts just until the end of the day with wifi on & the default Android 6 OS. I typically use WhatsApp & e-mail occasionally during the day. If I use GPS navigation or SnapChat (for some reason, taking & sending a picture there takes a lot of battery power) it will drain faster.
I’ve been owning a FP2 for nearly a year now. One of the first things I remarked was the lack of battery power. So a friend and me decides to find a way to put more juice into it.
The design is intended to:
meet safety regulations by taking the hardware of an existing battery case for another phone
Add heat sink capacity by including a 1€ coin above the CPU
maintain one unique external USB port for charging (both battery and phone) and data access
cost less than 50€ in total
We found a way with a KiwiBird battery case originally designed for Samsung Galaxy S7 (similar dimensions as FP2).
I just posted hte design on Thingiverse: https://www.thingiverse.com/thing:3414721
